Discuss Determining cold feed and shower pump criteria in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Marc Taylor
    Marc Taylor New Member
    Before I start I believe I need to determine whether my bathroom cold feed is mains or from the loft tank.
    Would turning on the basin and bath taps and closing my stop cock be the test?
  2. ShaunCorbs
    Open the bath/basin tap do you hear the tank running
    Or you can do what you have suggested Open the kitchen cold tap first tho so you can confirm it's off
  3. Marc Taylor
    Shaun thank you for your reply. What I did was open both taps having turned of the ground floor stopcock and nothing came out of either tap and the toilet did not refill
  4. Marc Taylor
    so have I identified bathroom cold is mains fed?
  5. ShaunCorbs
    correct so the tank only prob supplies the hot cylinder
  6. Marc Taylor
    No as I know the hot tank is gravity fed, did I need to do that as well
  7. ShaunCorbs
    No dopy me read that as I've opened bath taps and no water came out :D
    Yes you have found the cold main
  8. Marc Taylor
    Apologies Shaun logged out and forgot my new password hence my delay.
  9. Marc Taylor
    My primary question is the bathroom is my bathroom is 4 mtr by 3 mtr, in opposing corners is the bath and the hot water cylinder. The bath having a bristan mixer tap unit one spout and a knob you pull up to fed a shower. in the opposite corner at 1.5 mtr the hot water cylinder fed from a cold tank in the attic. this set up will not hold the shower knob up.
  10. Marc Taylor
    so I invested in a Salamander Pump, with Salamander declaring this set 'Negative feed' with cold mains being blended with pumped hot. my plumber feels this is incorrect, another call to Salamander who maintain this criteria over the relative heights of cylinder cold tank and shower head, can you advise. Salamander have sown seeds of doubt, I do not challenge my plumber but the pump once turned on is none returnable, I'm popping out to run my son home back shortly Shaun.
  11. ShaunCorbs
    Correct and probably the cold is pushing the hot back unless you have check valves etc
  12. ShaunCorbs
    Do you have a single or dual pump eg connections one side or both
    As your feeding a bath mixer / shower
    Really you should have a twin negative pump
    So both feeds are balanced and equal pressures
    This will mean taking a feed from the tank and your hot water cylinder
    Hope this answers your question
  13. Marc Taylor
    The pump Salamander recommended is the "
    The CT Force 30 SU Universal pump from Salamander Pumps has a robust brass end and a brass impeller. This pump is therefore designed to meet the increased demands for water supply within the home.
    This single ended pump will quietly and efficiently boost the hot or cold water supplies to the shower or individual taps and outlets in a negative head gravity fed installation. " Your comments gratefully recieved.
  14. ShaunCorbs
    Right ok so it's a single pump
    So your asking if mains cold and pumped hot is ok ?
  15. Marc Taylor
    Yes and is my set negative feed. I noted within their spec sheet "
    The CT Force 30 SU Universal pump is a 3.0 bar single regenerative shower pump suitable for boosting water performance in a gravity fed negative or positive head system. It can be used when the cold water is mains fed." which confuses me further
Loading...
Similar Threads - Determining cold feed Forum Date
Mixing Hot and Cold Water; also a Sink Bypass Bathrooms, Showers and Wetrooms Today at 7:56 PM
Bristan Shower going hot and cold Bathrooms, Showers and Wetrooms Friday at 5:00 PM
