Discuss Difference between an unvented direct single coil solar cylinder and an indirect ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
- Status
Hi all. I have a customer who has bought a Potterton direct single coil solar unvented cylinder which was to be connected to a solar panel. The situation has changed and now wants it to be fitted at another property to a central heating system. I have called Potterton to see if this is ok and they have said no but could not tell me why. Can anyone tell me the difference between this cylinder and a normal indirect cylinder. Many thanks.
Re: Difference between an unvented direct single coil solar cylinder and an indirect
perhaps position of the coil. do you have specs? I guess you already have your answer from manufacturer.
- Status
Reply to Difference between an unvented direct single coil solar cylinder and an indirect ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, basic question, any insight much appreciated.
Looking to have an outdoor tap in my front porch fed from 15mm pex coming up from suspended floor. Pic 1 is inside porch, pex temporarily clipped to give an idea of pipe placement (ignore shoddy blockwork of booted cowboy builder!), Pic 2 is...
