Discuss Direct unvented cylinder 210 l in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ehc direct unvented cylinder 210L capacity, brand new and never fitted, comes with pressure reducing valve and expansion vessel.
Reply to Direct unvented cylinder 210 l in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Do most composite valves now for unvented cylinders have a tee on them For the expansion valve connection? The ones I used to fit just had the balanced cold connection coming of it. Them I tee'd off downstream of the composite valve for the expansion
Hi my daughters Ariston Cylinder has started to leak around the Emersion heater. She has never used the emersion heater so I was wondering if there was anyway to take it our and fil the hole with a blank? Or if anyone knows where to find an Ariston cylinder 150L unvented??
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from the shower but it seemed no different from the original combi boiler hot feed. There is (unusually) a lever that lets me select the combi or the...
Steveo111
Hi all, looking for some recommendations for a slimline indirect unvented cylinder to go with a new system boiler that we're having installed soon. Only need around 120/125 ltr for our usage and could possibly make do with 100. Been looking at a few different brands including the Megaflo which...
Hi All, I have recently changed heating source to a heat pump and so I have had a new water cylinder installed (different internal element required). This means that I have a 2.5 year old StainlessLITE Plus Horizontal unvented mains pressure 204L cylinder left over. We had it installed in Jan...
Peter M
