Discuss Dishwasher connection. No space. Head ache. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Tom2010
Hi all.
I'm putting a new kitchen in my flat and being an old Georgian building nothing is square or level.
I measured the kitchen but obviously didn't allow enough tolerance as my dishwasher is super tight.
The dish washer measures 600mm wide and 550deep.
My void for it is 600mm (so ok) but only 595mm deep. Therefor I'm lacking space for the trap and waste.
The waste pipe pipe is in the same location as well.
Have you guys guys got any good ideas? Is there a slim line trap on the market? Or could I use 32mm pipe?
Cant find a dishwasher connection for 32mm tho.
As a last resort I could locally chop off the plaster, as it's quite think. This would give me another 25/30mm
any thoughts ideas welcome.
Many thanks.
Tom
kitchen sink next to it?
595-550=45mm
a bit tight but??
am I misreading this?
Either put the waste and tap in the cupboard to the side
or sometimes the backs on washers /dishwashers aren't flat and there's enough room to put the upstand waste to one side.
buy a sink waste with a spigot for dishwasher. Job done
Hi all.
I'm putting a new kitchen in my flat and being an old Georgian building nothing is square or level. Tom
You having a laugh.
I've worked in new properties and the walls aren't straight.
Our house was built in the eighties, one kitchen wall wasn't square and all internal doors were replaced and most weren't square either.
Built in dishwashers are normall to tight to get any plumbing behind. Therefore the wast and cold are installed into an adjacent unit.
Reply to Dishwasher connection. No space. Head ache. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
My mum is trying to connect a washing machine and dishwasher in her kitchen. She got a guy out to do the job and he ended up making a hole in her washing machine hose and ramming the dishwasher hose into it, held together with masking tape and charged her 200 quid for the privilege of her...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built downstairs shower room. Recently he had this downstairs shower room re-fitted/decorated. Quite a simple set up consisting of a sink, toilet and shower...
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the branch) and plan to place it the opposite end of the room. I was pretty lucky to find a 110mm sewer waste pipe below the old sink which is the new...
My dish washer and washing machine are installed next to one another per the attached picture. After using the washing machine waste water per the attached picture fills the bottom of the dishwasher. In the attached picture this the waste water after 2 washing machine loads. Attached is a...
1K
Hi, I would appreciate any help on the below please. Can I install a reversed P-trap in a run of pipe from my sink to raise pipe? I have an existing waste pipe that disposes the washing machine waste, I am adding a sink to the configuration by connecting a T to the existing waste pipe and...
1K
