Discuss Dishwasher waste pipe extension help! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all
Grateful for some guidance - I have a new integrated dishwasher and the waste pipe does not reach the trap. I have seen extension kits on sale but am confused.
The end of the waste hose from the dishwasher is I think the standard 22mm rubber end. There are plastic connectors available to connect this to another hose (22mm x 22mm connector). But the hoses typically have 22mm x 29mm ends, and because I need it to end at 22mm to fit the waste trap, im assuming I need to join the 22mm end of the fitted hose to the 29mm end of the extension hose. But there does not seem to be any connector available for this!
I believe the old setup in the house had basically used a 22m x 22m connecter that was jammed into the 29mm end, but with this setup, the hose at risk of breaking and there is no room to fit a jubilee clip.
Moving the waste trap closer is not an option. Replacing the hole hose from the dishwasher is, but I would like to avoid if possible!
Any guidance would be appreciated.
Thanks.
Rob
Thanks for your suggestion appreciated - I will try and find a shorter one otherwise it will be nearly 4m!
One of the ends on this is 19mm - does this fit to the same trap connection as a 22mm?
Reply to Dishwasher waste pipe extension help! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
