Discuss DIY Guide To Installing a Wetroom. in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. brum
    brum Plumber
    hi there either tank walls floors to get super duper seal improve tiling skills or change grout I always use Bal waterproof grout rec for swimming pools hope this helps mate
  2. mutley racers
    mutley racers Plumber GSR
    Nice thread. I need to quote for a small wet room. How long would you say to prep the floor area and add tray and tank? It is only a 3m X 1m room?
  3. Destroyer2813
    Destroyer2813 Plumber GSR
    Got a wetroom to quote for also downstairs screed floor shower floor area is .75x2000 with a screen would you say tank floor outside shower area as well ?. And what kits best for the floor of matting ?
  4. Ermintrude
    Ermintrude Plumber GSR
    Thoroughly annoyed , used mapi silicone and it's come away from movement joint between travitene in my house and it looks gaff. Any suggestions ?
  5. kay-jay
    kay-jay Trusted Plumber GSR
    Is it not the travetine rather than the silicone at fault? Was the trav oiled or have any treatment on it
    • Like Like x 1
  6. SimonG
    SimonG Trusted Plumber Top Contributor!!
    Prob the travetine sealer at fault there ermi.
    • Like Like x 1
  7. SimonG
    I always tank outside the shower. Makes sense whilst your on. Last kit I used was BAL.
    • Like Like x 1
  8. Whyme
    Whyme Guest
    Probably been said previous but use marmox board strong as double the thickness ply. Just adhesive on then screw + tape and paint the joints and screw heads sorted.
  9. Ermintrude
    No trav natural and it was washed. Plus it's a cut edge it's between. Wall to floor.
  10. Whyme
    Whyme Guest
    Is the floor flexing??
  11. Ermintrude
    It's tanked the whole room is 1200 high on all walls and shower 1800 floor complete. resin glue between 18mm marine ply and joists, then full coverage of ply face with resin and another 18mm sheet. Impey tray sat on joists with 18mm between joists
  12. Ermintrude
    No. Used a clegg hammer floor dosnt deflect. Under normal use. 6kg hammer came back same as byson pre camber with 75mm structural screed. ( byson spanning 9m - my floor 2.8m) I sealed joint in rest of room with grout but silicone in shower area . It's lasted 6 years
  13. mutley racers
    Why do you need to put 2 X 18mm wpb? I thought one would be enough. So bal is the tanking kit to use then?
  14. Whyme
    Whyme Guest
    It must have just peeled from the chalky edge of the travitine then. treat the joint edges with that sealer stuff.
  15. Whyme
    Whyme Guest
    He's a big lad..
    • Like Like x 1
  16. mutley racers
    That's True
  17. Ermintrude
    Old house expensive coaving below. Roll top shower loo sinks and a pallet of travitene
  18. Destroyer2813
    So just use paint on tanking as normal on floors and lip up wall as required
  19. Chalked
    Chalked Plumber GSR
    Normal silicone, even good quality will not stick to stone. The curing process it too quick and it then detaches.
    This is the only one I use on stone.
    MAPEI adhesives sealants chemical products for construction
  20. Ermintrude
    That's the crap I used. I bought the buff one.
  21. Chalked
    Chalked Plumber GSR
    Normal mappai? Mappai ac, or lm?
  22. Ermintrude
    From poo fix?
  23. Chalked
    Chalked Plumber GSR
    How long between sealing the trav and siliconing the joints?
  24. Chalked
    Chalked Plumber GSR
  25. Ermintrude
    Ah! Sealed it about 2 weeks before - delay due to holiday !
  26. Ermintrude
    Will get some lm
  27. Chalked
    Chalked Plumber GSR
    Clean the corners to be sealed with a piece of scotchbrite. Vaccum up dust and clean with a dry rag before sealing.
    • Like Like x 1
  28. SimonG
    • Like Like x 1
  29. Ermintrude
    Bal mastic or tanking kit?
  30. GQuigley67
    GQuigley67 Trusted Plumber GSR
    Nice thread mate kudos!
  31. jamesdrainage
    jamesdrainage New Member
    Wow, it's perfect installing guide for wetroom
  32. Chuck
    Chuck Active Member
    I smell spam.
  33. ShaunCorbs
    Already sorted
  34. William Norman
    William Norman New Member
    Abacus do some nice videos
Loading...
Similar Threads - Guide Installing Wetroom Forum Date
Installing Mermaid laminate panels Bathrooms, Showers and Wetrooms Nov 5, 2017
