Discuss Do I need isolating valves on every electric shower in a new build? in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Rosco
    Rosco New Member
    I am installing 2 electric showers and the feed comes out of the wall. I would prefer to mount the unit over the pipe so as to hide any pipework. There is a isolating valve to the upstairs supply so I don't want to fit each shower with one if I can help it. Any advice re building regs/ water regs would be useful. I have looked at the building regs but can find no mention of it.
    Thank you
  2. king of pipes
    Read the shower manufactures instructions for fitting the unit and stick to them you will then be adhering to the regulations , it is common practice to have a individual isolation i would say yes they both need it . cheers kop
    • Like Like x 1
    • Agree Agree x 1
  3. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    Can you get access to the pipes on the opposite side of the wall ?
  4. Jones82
    Jones82 GSR
    You can sometimes fit one inside the case, using a bent service valve for example, which is an isolation valve designed to go straight on a half inch thread. However some showers now have a push fit half inch connector so you might struggle.
    I'd approach it with common sense, is the water easy to isolate under sink etc? If so I wouldn't worry too much. It falls more under good practice than actual regulation.
Loading...
Similar Threads - need isolating valves Forum Date
Advice needed... Gas Safe Registered Plumbers Only Jun 11, 2018
price of petrol up n up? Do you need to put hourly rate up? Plumbers Cafe Jun 5, 2018
