Discuss Do I need pressure valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm just a DIY person who has seen references to pressure regulation. I'm about to change my kitchen sink and wondered if I need to do anything about pressure. My supply is cold - straight of the main, hot via combi boiler. the present sink has nothing, (not even isolators which I shall fit, but it was installed about 35 years ago.
thanks for any advice.
No if your happy with the pressure atm and don't think it's too much just fit good quality full bore isolating valves
Reply to Do I need pressure valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My outside tap has had really low pressure after the cold weather a few weeks ago. Its connected from under the kitchen sink, and can be isolated from turning a flat head screw type thing a quarter turn. Any help or advice would be much appreciated!
Hi, guys! Hope you are all well. I have four solenoid valves connected to the main water supply, and they seem to break quite often. I believe it's the pressure that's causing this. I was thinking of adding a pressure valve to control the pressure before it goes through the solenoid valve. Do...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air gap as I was having dripping from the pressure relief valve. Since then I've lost a lot of pressure from the hot water feed to my shower. The rest of...
Hi, I am trying to increase the pressure in my gas boiler and was under the assumption it just involved opening these two small black valves. I have tried this but the pressure gauge on the boiler hasn't budged? Anyone know why this is?
C
Hi all. I hope one of you may have the answer i am looking for. I have four solenoid valves connected to the main water supply and they break all the time. I too have them istalled based the manufacturer requirments but i believ the water pressure is too high and they don't last long. I was...
Christos83
C
