Discuss Does anyone know off the top of their heads... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
Does the body of a clicker basin waste tend to be longer or shorter than the body of a pop-up (rod operated) waste?
Lol , both useless pal , I always use the "captive " type waste
( like a spinning disc )
Same length ish within 5mm
Had a few of them stick so you can't open them
Never had it myself TBH , but I can imagine a small piece of grit will cause problems . I always tell the cust to clean them with soap and water whilst spinning it. Worked up to press
1-2mm in it.
Never had a problem with the spinning ones only , the clicker ones which are a good source of income nowadays with changing them.
I have had problems with both but quite often is the customer at fault. Not clean, dental floss to name a few faults.
Reply to Does anyone know off the top of their heads... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
