Discuss Does it exist....... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
Mortar in a silicon tube or something similar?
Already mixed so you can just fill a hole quickly and without mess.
You can buy a thing that looks like a silicon tube but you fill it yourself before you use it. Never seen one with ready made stuff in.
Unless you can still buy Mastic guns?
Looks good but you still need to mix up then clean it out.
Something you can use quickly on a service or CP12 when the flue isnt sealed would save lots of time and effort
Google 'repointing gun' and 'mortar gun'. You still need to mix up the mortar yourself, of course. IMO, not really worth the effort for just one or two holes at a time.
Scott , dont bother buying the mortar gun , I bought one a while ago , I am still experimenting with the mix but as you compress the sand and cement it cloggs the end of the gun up .
Needs to be runny like warm honey
You can get it pre mixed yes and no the pre mixed stuff isn't
I bought one of those mortar guns a few months ago to do some repointing. It was absolutely awful after the first squeeze, cracking idea but just doesn't work, tried different consistencies, plasticiser etc.
A bag (I think they're called a grout bag) works much better imo.
Mortar just isn't compatible with the type of product you're after, however if you do find something, let me know :D
I’ve seen blokes use them loads on site to point in pre-fab chimneys. They seem to work a treat.
We use a product called 'Flashcrete'
You have to mix it but it dries in around 5 minutes.
For patching small holes it works great.
For flue work I do use fire retardant foam in a gun for infill to set the flue, 20 minutes later I point using a minimum of mortar (mixed myself) to make good, if you want that to go off any quicker use cement hardener.
You won't get true cementitious products such as traditional mortar or plaster as wet premixed in a dispenser because cement curing isn't a process of 'drying', it's a chemical reaction and cement will actually set underwater or in a sealed container once it's mixed.
Perhaps this could work never tried myself but tempting to be honest Fischer FIS V Hybrid Mortar Resin 360ml
Reply to Does it exist....... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I fix what I can around the house myself and have fixed a few toilets but I need help with this one. This toilet keeps running and stopping, running and stopping, etc. I've cleaned the rubber flapper itself and at the point that it contacts the reservoir, so I don't think it's leaking from...
Hi all. Shower is leaking into downstairs when water is being aimed at wall . All sealant has been redone on outside and between shower tray and wall at the bottom on inside , can’t spot any leakages here. It runs down the wall downstairs beneath shower in lines , when water is sprayed at the...
Do people with this type of mixed flow temperature control have any problems with achieving the required manifold flow temperature? The one below I think is similar to the TIO Mixing unit. In the unit below, the hot (boiler) water enters from the bottom left, red arrow, up through the "mixing...
hi all, hope you are all well, i was just about to start siliconing my shower tray (long running project) and found the exp date on the tube FEB 23. the silicone is a DOW 785 unopened. it was stored in a cool dark place. is it ok to use? thanks
Think I know the answer is no but asking just in case. I have a solvent weld bathroom waste with lots of connectors in it that disappears into the wall with a right angle connector. There is no place to break into it to connect up a new arrangement for a new sink. So does anyone make a...
