Discuss Drain rodding point overflow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello,
There’s a ‘drain rodding point’ which lies in the alleyway exactly between mine and my neighbours house, equidistant between the outsides of downstairs toilets in both properties. This evening I noticed that the cover was loose and an area about 1 metre squared covered in waste (toilet paper etc). Nasty. Am I right in thinking this has simply ‘exploded out’ and indicates a major blockage? There doesn’t seem to be much information on similar happening. Also, is this likely to be a shared pipe or will it belong to either property?
Thanks in.advance for help.
I would say it needs investigation
It may be a blockage that built up a bit more pressure than the rodding eye could handle. The pipe should really belong to one of you, its unlikely to be shared.
If the blockage is in a shared section of drain or lies outside your property's boundary, it is likely to be the responsibility of the water company.
Reply to Drain rodding point overflow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
