Discuss Drain valve head has come off? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've been off supply for water for a couple of days due to very bad weather. It's starting to thaw out now but ice forced out one of the valve heads. Is this a drain valve in the picture? Is it OK just to push it back in or would I need a plumber? There's also a ring on the floor which fits it (second pic), should I just put that over the end and then push it back in?
Thanks for any help
You got any adjustable spanners ?
If not best to call a plumber out simple fix shouldn't cost much
That's a compression fitting , on the frozen pipe, with Olive , the ring on the ground, that the drain cock fits in.
Where the Drain cock has come out there's a nut.
This needs undoing and the nut and olive reassembling and tightening back into the fitting.
If you've never done plumbing find someone who has, you'll struggle to find a plumber available this weather.
Turn the stop tap off til it's fixed or you may get when when it thaws out
Reply to Drain valve head has come off? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
