- Messages
- 10
Discuss Draining system safely in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OMG that's bad, I'd strongly advise getting a plumber to redo that, won't take long to put it right so shouldn't be too costly.Did you do that shower pump yourself ?
Hopefully he won’t get an airlock afterwards.Just isolate your f&e tank in the loft and that’s all. If it doesn’t have any means of isolation you can shut off your main stop tap instead. Remove the radiator and drain from the valves or if your lucky enough to have a drain off use that.
Reply to Draining system safely in the Plumbing Jobs | The Job-board area at PlumbersForums.net
