Discuss drill hole into cast iron pipe? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jennie
Hi all,
I need to re-route two pressure relief pipes (one from a combi, one from an unvented cylinder). (I have my unvented qualification).
I'm going to run them both into a tundish, so there'll just be a 22mm pipe to re-route.
Pic below. An extension was done, and pipes are being dealt with retrospectively.
There is the bottom part of a cast iron pipe (rainwater?). It has an overflow pipe from the water softener feeding into it.
Could I run my 22mm prv pipe into it? I'd need to drill a hole. I have a diamond saw bit (also in a pic).
Otherwise, I'm looking at a longish pipe run to get it to the outside wall. I should be able to do it in under 9m (including the bends). But the customer would rather not have a termination pipe on their outside wall.
What do you reckon?
Thanks for your advice,
Jennie
You'll get through with that just fine. Slow and steady and keep the bit cool. I just keep a small container of water next to the job so I can keep dunking it. Even a good Bi-Metal hole saw will go through cast with a bit of patience so that diamond bit you've got will drill through that. The cast iron pipe will be fine if there is something like a basin to flush the pipe out during use. Worcester Bosch put out a technical bulletin about cast iron and condensate from boilers. The D2 from the unvented is fine to take into the cast iron.
TB 0083 a - Condensate discharging into cast iron pipework | Worcester, Bosch Group
If it is a rainwater pipe and the local drainage system is separate foul / surface water, then:
1. The water softener overflow shouldn't be going into it as it will overflow salt water.
2. The boiler condensate shouldn't go into it as its mildly acidic.
3. The unvented cylinder can as its clean water (well at least as clean as surface water).
Reply to drill hole into cast iron pipe? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I need to this cast iron pipe back as my new back to wall toilet won’t fit otherwise. Cutting it back i am going to lose the collar. So what fitting can I get for it I would like a flex as it will easier for me when installing the new toilet
Dear colleagues , My name is Roohollah and an overseas Heating tech. I have recently collected some data on oldest cast iron boiler from UK which is called Robin hood boiler . Thus, I would like to request for any data or pics of those products if you ran into them before. Thanks a bunch for...
Hi, Helping a friend, his soil stack is cast iron. The bath and basin wastes (all removed now) went into individual entries on the stack. These are iron pipes, with what looks like a female internal thread into which there is some sort of metal reducer with what is maybe a compression fitting...
Hello guys, an easy one: I recently had to drill through two outside walls to run 15mm pipes for a shower and sink. The holes are neat enough but need to be closed off to prevent draughts. Can I use expanding foam to block them? I wouldn't do this with central heating pipes, but the shower and...
60's ranch, with single bathroom. Tile over concrete slab. Toilet is about a foot from exterior brick wall. Vent pipe is in interior wall behind toilet. There's a concrete patio outside the bathroom, that extends about 10 feet from the wall. I'm considering adding an ADU in the back yard, and it...
