Discuss Ducting system for heating pipes in concrete in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Hi all. Does anyone have a manufactured system they use or make up their own out of plywood? Seen some ducts in BES but at £16 + vat for 3 metre is expensive and then you need to cut the ply top.
Can kuterlex plastic coated copper pipe be buried in the screed without insulation or ducting?
Cheers all
Put it in conduit, you can get either plastic or mlcp in conduit pre done
Used the poly pipe plastic in plastic and it was a bit tricky to work with. Was looking for something a bit easier
What's the design (system)
Reply to Ducting system for heating pipes in concrete in the Plumbing Jobs | The Job-board area at PlumbersForums.net
