Discuss Dudley Turbo 88 Adjustable Duoflush Syphon in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The above unit has just been fitted by a plumber. However the flush time is 12 seconds and is less powerful than my previous syphon and does not appear to clear all solids from the bowl.
Is there a restrictor in this syphon unit that needs to be removed to improve the performance or is this how it is meant to work?
Also from the instructions it suggests there is a "Reduced flush" option but this does not appear to be working - you either get a slight trickle of water by gently touching the handle, or if you lower it too much, you just get the full flush lasting 12 seconds. Am I missing something?
Does it empty the cistern minus a little bit left in the bottom ?
Flush time 12 seconds? Please explain what you mean.
Cistern has a small amount of water left in the bottom after full flush about 1" deep. Flush time 12 seconds is the time for all the water taken to drop into the bowl on the full flush.
Close coupled toilet & cistern?
If you disconnect the flush lever from the syphon and pull out the Yellow pin the Blue section (the syphon) can be removed leaving the White tube where the water flows through. Pour water down and see what happens as thinking somehow there is a restriction there (?).
photos herewith.
we know there is a problem - it takes 12 seconds to empty the cistern. Post 17 hints there is a restriction in the bowl -syphon tail too long. Would shortening this tail solve the problem?
Reply to Dudley Turbo 88 Adjustable Duoflush Syphon in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A few years ago I repaired my parents 35 year old toilet with a Dudley Turbo 88 and Syvac aspirator. It's started leaking from the donut I think. Also the Syphonic action had died and the solids hardly moved with a flush. I've removed the tank to take a look and the Syvac aspirator has snapped...
1K
I have a high level cistern and was replacing the toilet pan (waste ceramic completely cracked through) and was hoovering around before connecting the waste and the lead inlet pipe and was just absent-mindely gently sucking lead filings out of the inlet pipe - and whoops, the downpipe grabbed...
3K
Cast_Iron_Cisterns 486
C
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical, carpentry it's been never ending. The house was built by Barratt Homes in the year 2000, it is a 3 bedroom house called a Palmerston, the CH/HW system is a Y...
5K
I am having a real problem with a leak that commenced a couple of months back re my folk’s WC. It is a straightforward Armitage Shanks low-level type (relatively old) that started leaking underneath the WC from the siphon connection. I took the thing apart and it appeared that the siphon sealing...
3K
  • Locked
Hi all, Need to replace my toilet syphon in an armitage toilet. I measured from the bottom of the internal cistern to the very top of the syphon. This was roughly 275mm which is pretty much 11". Is this the size I need to buy? They come in all different sizes 7,8,9 (litres or inches). It is a 9...
8K
