Discuss ECV letby on boiler install job in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
hi peeps,
Just tested the gas pre boiler install and the ECV is letting by. Obv I won’t know if there’s a drop on the system until the ECV is replaced, do I halt the install until this is done or carry on cuttinggas pipe so I can take the oldboiler off?
Cheers
Have you phoned it in ?
Anyone ever replaced a Keston with a new Keston and joined into the existing twin flue?????
Yea needs to be the right stuff, but I think you have to pressure test the flue to make sure it's sound
How do you pressure test it? Sean can you give me a bell please as I need to order the Keston in next 30 mins
Air test it like drains
Where do they exit on the property?
The roof I think as can’t see them coming out the external walls
Need to check it's supported and terminal is correct etc
Also need to put your bung in it
Yeah ... jobs been a nightmare today!
Just trying to think where I could get a pressure test kit?????
Nothing like this ?
You must be able to make something up?
They're both open ended so it doesn't need to be a big pressure just as Shaun said, a quick drain test will do.
I don't know the cut off times but you can choose delivery by 10 the next day.
You get all the fun jobs jay
How's self treating you
Ah can't complain mate, busy which is great.. Business is going well. Basically all I got done today was getting the old boiler off the wall and Cadent fitting a new ECV!
How about you Shaun, how's things?
That's good and you get some days like that
Just have to move on and do something else like hang the boiler and sort the flue out or flush the system etc
Very good slowly ramping up the kids are off so the schools are starting to pick up
Reply to ECV letby on boiler install job in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
