Discuss Electrical counter for CH in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hiya new to forums so sorry if the wrong place.
I'm currently planning a thermal store installation for a new property being converted into a hmo .
I would like to zone every single bedroom and give the teanants a switch (like a light switch) which is also run into a tamper proof thermostat set to around 22.5degreec.
Is there any products which act as a timer when received a switch live will start to count, which I can take from the thermostat, to monitor the use of each individual's heating usage in hours .
So every month the landlord will be able to see the following
Room 1 : 13.4 hours
Room 2 : 7.1 hours
Room 3 : 2.5 hours
So on and so forth.
Thanks in advance .
Room 1 : 13.4 hours
Room 2 : 7.1 hours
Room 3 : 2.5 hours
So on and so forth.
Thanks in advance .
We sometimes use Hours run counters like this if that's what you mean?
They look like they would do the trick, do they only count when a 230vac is detected and when the signal is lost (heating turned off) it remains at the number without resetting .
Thanks for your reply .
Yes.
We occasionally use them for counting the run hours of Boilers in Commercial premises. The clockwork ones are probably best. Simple and straightforward.
If you wire one off the switched live from each room stat to its Motorised valve it will be on all the time the Heating is running in that zone.
Would it be worth connecting them between the switch and room stat? If it’s for billing it could be unfair on those in the colder rooms?
Sorry - ignore that!
Reply to Electrical counter for CH in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Background 24 apartments are equipped with thermal stores of (100 to 150 litres) with immersion heater capability. Individual demand of each apartment for domestic hot water varies greatly in timing and volume. Thus the oil boiler is required to work for long periods which is uneconomical...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
Our current heating system has a Potterton EP2002 controller and Potterton Prima 60F boiler. I have bought a Wiser multi-zone kit 2 plus a number of Wiser TRVs in order to have easier and more fine-grained control. Replacing the EP2002 with the Wiser hub simply involved swapping the wallplate...
2K
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm. This question is for my own house setup. We are really fortunate to have a large house, about 5,000sqft in total over 3 floors. It was built around...
1K
H
HRP123
H
