Discuss Elson Coral E water overflow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
- Status
I have an issue with my Elson Coral E water heater. My expansion tank constantly overflows and the water is constantly leaking into the drain. I have checked and the float valve is not the cause of problem - no water running from there.
I suspect that an element inside that controls the water pressure from the main does not work properly. Could you please tell me what potential issue could be? Could it be damaged heating coil that let water run instead of stopping it once the tank is full?
Sergej
- Status
Reply to Elson Coral E water overflow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I’ve noticed my ballcock valve is always running in the loft on the small f and e tank but when heating is on its fine, also no water coming out of the overflow, any ideas.?
Hi all
I have a problem with my hot water header tank getting warm water into it from the bottom of the header tank (not the hooked overflow/expansion pipe. Hence the header tank then reaches the overflow level and the overflow trickles out.
I have changed the ball valve washers thinking it was...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
Hi all,
Just recently noticed the overflow has started pouring water out, there are three tanks in the loft and I'm quite sure this is from the heating.
We have two boilers, one for water and one for the heating, it's an 8 bed Victorian house (bed and breakfast)
I went into the loft to see what...
Hello everyone. New to the forum and looking for assistance / advice.
I live in a rented house with a not very co-operative landlord. I have just discovered that my bath overflow drain pipe is not connected as the flexible drain tube looks like it has been cut off at some point. After studying...
