Discuss error 403 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
nysk2008
trying to post on the GSR forum but getting error 403 - what is this?
I am getting the same! in any forum, this one?? something about cookies??
It's whenever I try to post a long thread that the error occurs. I've tried ie, Firefox and chrome all produce the error.
Last time this happened the server security software had issues with Facebook. Dan wound the security software back to a previous version and that seemed to fix it.
Trying tapatalk now!
ok here!
is your activex up to date and cache cleared?
or you have conflicting plugins?
Reply to error 403 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello Wondering if anyone can offer any clues please // Potterton Promax 18 // Had an E1 error code, repressurised via with filling loop // Boiler fires but now the pressure runs up from 1.5 mark in the green up to 2.5 in the red then flicks off. // Error code again // Once held in reset for...
Hi, Trying to submit a question but I get a request to ask the Admin, can you help? I have tried to paste here but get the same error, hope you can help? Best Regards, Phil
We have an oil delivery booked for Friday but we ran out earlier today. We topped the tank with 150L from containers, bled the first boiler from the Allen key until the oil ran free and it fired up fine. Did the same on the second one but that had an E9 over temp error. We reset the thermostat...
Hi, I'm hoping someone here may be able to help me out with an issue I have with my baxi duotec boiler. Basically, the hot water temperature has been fluctuating quite alot, dropping in temp then raising again whilst showering. I have had an engineer out who has changed the thermistor, but I am...
J
Hello, I have a Bosch 35CDi, and today found all the lights flashing on the front. Normally I can reset the boiler, but this did not work. There isn't an error code, since even the error code display is flashing. I have searched the internet but cannot see this problem elsewhere, since every...
Deleted member 120897
