Discuss Existing Flange for shower pump ok? in the USA area at PlumbersForums.net
Im im fitting an ST 3 bar shower pump in place of an aqualisa that was previously fitted
Just wanted to check if the existing flange is positioned in an acceptable position?
The instructions recommend side entry and this sems a bit high (not sure what is considered side entry). Didn't have any issues with the previous pump but wanted to double check before final fitting
Yep aslong as it’s got a dip tube
Yes but be warned you don’t want to disturb the flange
chances are there’s no dip tube but it’s been working fine with the old pump so upto you
Reply to Existing Flange for shower pump ok? in the USA area at PlumbersForums.net
