Discuss Expansion tank is it big enough. in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. Bogart
    Bogart Member
    Doing a bit of a revamp of heating system some rads out new ones in . Took old galvanised expansion tank out of loft. Now I reckon this thing had a capacity of a good 100 litres. Looking at replacements they seem to be 18 litre and that is it. Now I have some 22 rads and what with a run to and from the boiler I recon there is roughly about 300 litres in the system. Using an online calculator it states that my 300 litres say at 5degC will be 317 litres at 75degC. Will not be this as obviously water might leave the boiler at 75degC but the return might be only around 45deg C so average is 60degC hence an averaged rise of 55degC for the sake of calculations. This give a heated volume now of 313.5 litres ie expansion of 13.5 litres.All this is leading to is an 18 litre expansion tank sufficient for my volume of water? If not is there an alternative to not using a cold water cistern sized thing which is way oversized?
  2. ShaunCorbs
    You sure it was an f and e tank and not supplying your cylinder (for your hot water) ?
    Also by the looks of your post your out of your depth as that calc is for a sealed system
    My best advice is get a gas safe engy in
    • Agree Agree x 1
  3. king of pipes
    I think you need to employ the services of a heating engineer Bogart regards kop
    • Agree Agree x 1
  4. Bogart
    Bogart Member
    Definitely expansion tank the water tank is next to where the expansion tank was. Not sure how you think my figures are for a sealed system.
  5. SimonG
    SimonG Trusted Plumber
    About 12 litres.
  6. Bogart
    Bogart Member
    Sorry lost me 12 litres?
  7. oz-plumber
    oz-plumber Plumber
    If what you are saying is correct - just go an purchase a 24 litre expansion tank.
    Could be an overkill - but it will work.
    I did some oldschool calcs - 18 should be fine but if it were me, I would put in a 24.
  8. Bogart
    Bogart Member
    I would if I could find one. Here we seem to go from 18 litres straight to 114 litres ie 25 gallons
  9. bacon_sandwich
    bacon_sandwich GSR
    Are we not at apples and pears here. Assuming the expansion tank in the loft is for a vented gravity system and the tanks he is looking at are pressure vessels for an unvented sealed system ? although i dont have any trouble sizing vessels in small increments here
  10. snowhead
    snowhead Well-Known Member
    Twin 18ltrs.
  11. Matchless.plumb
    Matchless.plumb Trusted Plumber GSR
    I'd recommend an Plumbing and heating engineer.
  12. Chuck
    Chuck Active Member
    That seems rather a lot. Between two and three times what I'd expect for a domestic system. DId you measure it by counting buckets when you drained it?
    How big was the old expansion tank? If you look carefully inside it you can probably see the high-water and low-water levels represented by rings of crud and corrosion.
  13. Bogart
    Bogart Member
    No tanks am looking at are for gravity fed system.
  14. Bogart
    Bogart Member
    Did actually think of that still a possibility.
  15. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    So are you trying to convert the system or trying to keep it as a gravity fed?
Loading...
Similar Threads - Expansion tank enough Forum Date
Expansion vessel hose popped off Gas Safe Registered Plumbers Only Apr 27, 2018
Expansion Vessel Siting Gas Safe Registered Plumbers Only Apr 17, 2018
