Discuss Expired flux keep it bin in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Evening all, Found 6 tubs of flux but they’ve all expired last year can you still use it or shall I just them away ?
Cheers
Tin of Fluxite at college. Gone thick, lid missing and rusty nail in the middle for some reason (the Level 1 students ?).
Worked very well.
Its main purpose is to stop the oxidation so I would have thought it shouldn't matter about shelf life if you think back to lead soldering wipe joints we used to use tallow,
While we're on about flux - what's the best??
1) Laco
2) Powerflow
3) do you remember that Yorkshire one in the green & white tub - it had a distinctive smell? Is it still available?
... and how many of you use lead solder where you can i.e. for gas and heating?
I remember lead solder performing so much better than todays 'lead free' with silver alloyed in :)
laco and unleaded, i was a powerflow guy but its too bitty on the fittings when your trying to fit them
OMG ! How old are you ?? :rolleyes: Ok me to ancient oldie ,Still got some Moleskin around somewhere, Ah the good old days When Plumbers were real men !!:D
There is still the old type Fluxite or similar Yorkshire “grease” based fluxes available. Still one of the best fluxes you can use IMO.
I still use it. Old and well proven. :)
I have a tin of Laco I must test though.
Laco all the way for me. It works very well using the thinnest of smears and therefore doesn't run out of fittings or make any mess. One problem I see with our students (and lecturers unfortunately) is that whatever flux they are using they put on way too much. The stuff is flowing out the fitting during soldering and dripping all over the place. The lads argue that they always clean their fitting up afterwards so it doesn't matter. I showed them a job that was a week old and indeed the fittings had been cleaned after soldering but there was green streaks all over the older pipework below from them using too much flux. I also cut out soldered pipe work and regularly find the flux runs all down the inside of the pipe and baked into the fittings, even after the systems have been flushed.
As a demo to prove a point, I cleaned a tube and fitting with wire wool, and applied an almost imaginary amount of Laco to the pipe only and got them all to solder this way successfully. I told them not to use such a small amount in reality as I was just demonstrating their excess but it did show they were all routinely using an excessive amount. There seems to be a real lack of finesse in some of the most basic plumbing skills with too many apprentices and even time served plumbers. I do my best to encourage skill and professionalism with all our lads.
I realise I've just gone off on one again but it's something that drives me nuts seeing floods of the stuff dripping all over the place plus it makes right mess of all my heat mats.
Templars Telux (grease based) for me. Just have to make sure you clean both pipe and inside fitting, as it's not self cleaning. Though for some reason, Laco seems to work better on solder ring if I use that type of fitting. Don't know why.
Laco , thats the one for gas . Lead free solder .
Laco on gas, i was told to steer away from laco on gas due to it being corrosive? Cant really be flushed? Used to use powerflow but its a bastard to get fittings.on with the slightest bit of water in the pipe.
As far as I know laco is the only one that should be used on gas , its powerflow thats the agressive one .
You maybe right, i use laco on everything but use lawtons on gas pipe because i thought laco was corrosive.
I have left Fluxite, Laco, and Everflux on a pipe for a week (as an experiment) to see how corrosivethey were. No green whatsoever on Fluxite, but still greasy (wet?). The Laco and Everflux had dried, but the pipe was heavily greened. I would not say Laco is non-corrosive, based on this.
The grease based Fluxite won’t be too corrosive, even if left on pipes for years, but I always clean it all off after soldering.
The Everflux is terrible and eats into the pipe. I hate it and never would use it. I regard it as pure acid and that probably explains why it is supposed to work on uncleaned fittings. I heard it can attack the solder and I have come across lots of fittings that have dry looking solder and some leaking.
Reply to Expired flux keep it bin in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
