Discuss Faulty actuator?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hammers4spanner
Subscribed
Just before i mashed my back i was asked to look at a commercial property where heating had gone down .
This valve was on the flow to high level coils and was buzzing like hell , the pumps other side seem to be fluctuating .No heat seem to be transferring through to other side .
Have you tried moving the dial ??
That mixing valve looks like it's in the " satisfied " position. It will then just circulate water through the heat scource. They do tend to buzz a little. You can move them manually and see if it then circulates.
Look for a weather compensator that controls it.
Ah and hereby is one problem I looked for an isolation point and couldn't find one.
Just change the head if the body moves fine
If it's got power (calling it to move for coil)
Reply to Faulty actuator?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
