Discuss FFS , one ish hour syphon swap , yer right in the Plumbing Jobs | The Job-board area at PlumbersForums.net
townfanjon
Subscribed
Got caught out with this job today . No isolation valve , stoptap wouldnt shut off, had to take cistern off a 40 ish year old pan and replace syphon , easy job eh .
Battled and put a Dudley on, new fill valve , handle etc etc.
But the bleeding thing will not flush properly , its obviously a syphonic and doesnt like the new syphon .
In the bottom of the old syphon is the “thing “ in the picture , its nact , covers a hole in the pan where the water enters .
Never seen one before , can I block it up ? , any ideas how to get it working , or am I flogging a dead orse ?
As usual , thanks in advance
Lol , ace !!
Have you any what it does and why it should alter it flushing ?
Lol , ace !!
Have a Google, once found a very good article about them for a customer after local handyman did what you did then blamed the sani for not sucking the waste away! :mad::mad::mad:
How I have never come up against one of these absolutely baffles me
I've only seen one, in easy terms great for massive ***** / loads much better than today's toilets
If you mean the toilet, you can tell by looking at the pan side on. Brilliant idea and great flush as you will see in time, generally last for donkeys of years without fault.
How old are you in Donkey years? ;)
Lol , bleeding old git status , I have seen loads of syphonics just not the aspirators.
I always fancied been a ****star , what a way to earn a living
You say that now imagine doing 10 years of that
You will need more than a blue pill to help the awaking
Take it you`ve read about the casting couch in recent media, now imagine a 60yr old saying "Prove it" to you! :eek:
Nah never time to read crap like that , spend too long on here and FB , if it is about sexual harassment, I am up for that
I have had this problem before, but I was completely bam bamboozled. A customer called me saying she had a plumber in to fix the toilet and it hasn’t flushed properly since. That was about 12 months ago. (I couldn’t fix it)I have just text them back to say I now know what it is and would they like me to have another look.:p:p:p:p. cheers Town.:p:p:D
I feel old now! :) I used to install those syphonic toilets, - Armitage brand. Best toilet made!
I repair them still. Not that they need much. The Airex must fit the syphon properly. Tip, - The domed washer on bottom of Airex has to be flat face down against the pan and to fit it correctly on Airex just means pushing it on first part of Airex stem and it will push into correct position when you lower the cistern down onto pan.
The Airex, or also called a bomb, if washer on it is damaged, will cause the pan to fill high up and then slowly drain away, similar to if sewer or pan was blocked.
A good plumber would know a syphonic toilet just by glancing at it. ;)
The pan is not as deep as a normal wash down pan and also if you look at the side of loo you usually notice it had a double trap sort of shape
What I hate about siphon swaps is the Ideal Standard sloping side wall cisterns where a normal shaped siphon wont go in, has to be round or D shaped. Aragh.
Also no room for brass shank jobbie so the nasty part 3 has to go back in. Plenty of room on the other side of the cistern but oh no, it all has to be squashed in on the right hand side why is this?
Or the new fluid master siphon ;)
I just tell em, "too old. no more spares" = new bog... Then they find out water is scarce in new ones :eek:
Best toilets out there. Can't beat a syphonic toilet. Always carry a bomb in the van. Lots of them round my way.
In my own house I still have an Armitage syphonic toilet from 1975.
Still near original except I replaced the small washer on the Airex 2 or 3 years ago.
Ordinary toilets now with the water in pan so low, just seem wrong
Ive only seen one of these once and thats when i was an apprentice and too young to appreciate the educational factor of it, seen the tradesman fit, didn't pay much attention and now i regret it because i just know i'm going to come across one of these in the future
Update on this job for anybody that’s interested .
Fitted a fixed height Dudley 88 ( not the adjustable)and there own aspirator ( thanks to RPM and Shaun ) from toolstation.
Flushing like a gud’un now.
Time wise its been a nightmare job , this is why I wont quote a price for 99% of my jobs.
This was just one of those jobs , it wasnt so much the aspirator, it was the rest , have a read and a laugh..
1 . Couldnt park within 100 yds
2. No isolation valve to toilet, no chance of fitting one, straight out of wall to tap connector, no movement.
3. Stop tap in cellar , he doesnt use the cellar,had to squeeze through a 1” gap to get to stop tap.
4.Stop tap wont shut off, found another , that didnt shut off. Opened all downstairs taps and bath tap before I removed the cistern, water running all the time
5. Fill valve nact , handle nact , overflow didnt line up .
6. Time used up to go to plumbs for new syphon, ordered aspirator off toolstation.
7. Tossing post man delivered parcel to next door and didnt leave a card , total fluke I saw the neighbour the day after and he mentioned he had a parcel.
I honestly could go on theres a lot more but I have lost the will to live lol
Oh the best bit , I charged him £150 plus parts
Think I would of walked at number 4 jon with no full iso mind you i have carried on before with a temp iso valve on the end of the cistern feed pipe before.
Reply to FFS , one ish hour syphon swap , yer right in the Plumbing Jobs | The Job-board area at PlumbersForums.net
