Discuss Firebird combi 90 air pressure switch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
hi guys, I've been asked to fit a second hand boiler to a caravan until there new house is built.
It's a firebird combi 90. I had a glance over it but it looks like the air pressure switch is all taped up?. Any reason why? I don't know the history to why it would be.
Any one shone light I would be grateful.
Regards dars
Reply to Firebird combi 90 air pressure switch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Worcester Bosch Greenstar 30Si combi boiler, the analog clock has stopped and the On-Timer-Off switch only works on Timer setting,. So I have set all the little timer switches to ON and the boiler does work then. Any help or source for a new clock would be great. TIA
What the easiest way to find why my boiler is losing pressure. It is about 5 years old Vaillant combi boiler, we have just had 2 vertical radiator removed and refitted for decorating and now the pressure keeps dropping approx once a week. I guess a leak under the floor is possible, or trapped...
Hi. I have a firebird enviromax combi boiler. each time it turns off the motor on the riello burner keeps running for a while then the whole thing goes into lock out. flashing green and red. shouldn't the motor turn off straight away? I'm also getting pressure building up while it's running...
3K
Hello The heating side of my Ariston Combi A23 has stopped working since a new 3 way valve has been installed. It's been a hugely reliable boiler up until now with regular servicing. When the heating is turned on the boiler ignites and looks to start up but then a few seconds in, knocking sounds...
A
We have a vaillant combi boiler that over ~ 2yrs loses a bit of pressure, and recently after 2 weeks away and no use the system would not fire and errored with F75. We attempted to refill, but the mains pressure is only 1.0bar, and the combi needs more than that to light. I ended up removing...
