Discuss Fired Earth Exposed Shower dripping badly in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
Thread Status:
  1. Smoggy
    Smoggy New Member
    Hi all,
    We recently moved into our house, (which had been unoccupied for a couple of months) and the shower was working perfectly to begin with. It's a Fired Earth Classic Exposed model like this one. After a couple of weeks it then started to drip quite steadily from the rose even though it was definitely turned off! The dripping stopped for a few days and now the dripping has come back. We live in a hard water area so I'm guessing that it's most likely a build up of limescale. Would this fit with the symptoms?
    The water feeds for the shower are behind the tiled wall so it's not easy to turn off the supply. Turning off the main stop cock under the kitchen sink isolates the hot water feed to the shower aswell as the cold so I could potentially take the thermostatic controller apart and clean it up if it is a limescale build up. The problem I have is that I have no idea what to expect when taking it apart or even if it's possible to clean it once it's apart.
    Any pointers gratefully received. Ta. :)
  2. stani
    stani Plumber GSR
    Speak to fired earth, there are spares readily available, however they are expensive.
  3. Smoggy
    Smoggy New Member
    That would be my second choice but if it's possible to clean it up without spending money on it then that would definitely preferable. ;)
  4. ShaunCorbs
    Sorry to say no once it starts dripping the cartridge has failed
    • Like Like x 1
  5. stani
    stani Plumber GSR
    As above there are no user serviceable parts on these
  6. ShaunCorbs
    Don't think you can even strip them, I'm sure there pressed together
  7. stani
    stani Plumber GSR
    Look fantastic, but a £60 center brand does exactly the same thing for £1200 less.
  8. Smoggy
    Smoggy New Member
    Bummer! But thanks for the info. I'll get onto Fired Earth and ask them about cartridge replacement costs. (Whilst sitting down, obviously!! :eek::D )
  9. ShaunCorbs
    Don't suppose you know how old it is ? I only ask as somtimes companies have a 5 year warranty
  10. Smoggy
    Smoggy New Member
    Yeah, I can't believe the price of them!! I'm damn sure I wouldn't have paid that much if it was my house. (It's rented, thankfully)
  11. Smoggy
    Smoggy New Member
    No idea but I'll mention it to the landlord.
  12. stani
    stani Plumber GSR
    Will the landlord not repair
Loading...
Similar Threads - Fired Earth Exposed Forum Date
Boulter Oil Fired Boiler Mystery... Central Heating Forum May 11, 2018
Thread Status:
