Discuss First vaillant green iq 627 service of system boiler. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a service for a vaillant 627 system boiler(eco tec pro).
For a first service I was told(for 65 quid)
you'll need a burner seal . Service and new G10 seal £65 ,
Is this correct as to what I need- when he hasn’t checked boiler?
if its only one year old it wont need a burner seal but the price i would say was too cheap if he was replacing the burner seal and other items (main service)
I always change the G10 burner seal as shaun says a proper service is more £75 plus the cost of parts seal is arond £20 so your enginneer is being more than fair should like something this when stripped and cleaned. Cheers kop
Reply to First vaillant green iq 627 service of system boiler. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
I got my regular annual boiler service for my Vaillant ecoTek 930 about a month ago, and the engineer identified that the AAV was leaking, so he closed it. This is a tenanted property and it's not straightforward to get access to it. How risky is it to / how long can I leave the AAV closed...
Cabe F
C
Hi, i've got a job with a Vaillant Ecotec 630 system boiler, and i don't know the full history but the house has definitely been extended significantly since the boiler was installed. There's now 21 radiators/towel rails. It's getting to temperature, but even after balancing, it's not heating...
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also have an UFH zone in the kitchen. Near the boiler I have 2 port valves which control this part of the system. The boiler has been loosing pressure...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler. Initially we thought the boiler may stay in place but after discussions with the builder we would have to move the boiler to replace the floor and...
I
Dear All, Please kindly advise, i don't know what else to do! Had new boiler Vaillant 424 heat only open vent boiler installed with new flue and filter, new pump, plus new Hive. Did full power flush of all 5 radiators before the installation. It has been 10days and boiler stil not working...
5K
Deleted member 120897
