Discuss Fitting Dishwasher after Saniflo in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My son is fitting this close coupled basin toilet (below) into a newly created downstairs cloakroom.
He started to trench the floor to take a full size soil pipe (4 metres long!) but we stopped him! He's now got a nice deep trench - too shallow for a soil pipe but plenty for a smaller pipe - and we suggested he fits a saniflo (usual objections about noise and cost). However he also want to put a dishwasher into the same outflow.
Seeing at there is enough space in the trench, is he better off putting the dishwasher waste in separate pipe to run parallel and sorting out the pipes outflow once it's outside the house, or joining the dishwasher waste after the saniflo but before it goes under the floor?
And, what's the best saniflo to choose for this situation?
I stand to be corrected, but I would assume you can't connect anything on the outlet drain of a saniflo.
The reason being that when the saniflo is in operation, the out flow from the saniflo has to go to a soil drain.
If the dishwasher was connected to the outlet of the Saniflo, when the Saniflo was in operation, then the dishwasher may end up with excrement within it drain pipe and probably the dishwasher itself.
Might not be healthy or pleasant
Would be ok if the dishwasher outlet joined the pump outlet from above and high enough and some distance away from the sani however that said I would run two separate pipes unless you knew what you were doing so yes I would go your way Oz.
Agreed. Why can’t the dishwasher run in to the Sani flow
Technically you can`t and to do so would void the warranty however that said within my own home I would do it but only in a certain manner.
Once you go down under the floor it has to be downhill all the way and a AAV may be required.
Thanks All!
Seeing as we have the space and it's only going to involve a few metres of cheap polyweld, we will put the dishwasher in separately.
How will that be outside? Can I get two separate 22mm waste pipes into an inspection chamber and then into the soil pipe running from the stack?
I feel a need for an access / rodding point instead of just bossing them in underground
Reply to Fitting Dishwasher after Saniflo in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built downstairs shower room. Recently he had this downstairs shower room re-fitted/decorated. Quite a simple set up consisting of a sink, toilet and shower...
Hi I've recently had a new bathroom installed. I've noticed when I flush the downstairs loo there was a hammer type noise under the bathroom floor when the cold feed for the loo turned off/ same with the washing machine. So I turned off the mains water supply. Opened the highest tap first...
Hi I need some advice as this has been ongoing since august and nobody can find a problem but meantime water is damaging my walls. The lady upstairs had a plumber in July who relocated her washbasin shower and fitted a new radiator.He caused a bad leak and came to fix it in august and I thought...
Morning all, A diy'er here. I'm installing a new kitchen in a room on the opposite side of the house and need run the sink and dishwasher waste under the floor to the opposite side and go out where the existing kitchen is, around 9m. The driveway and garage are outside the wall in the new...
Hi All I found this forum quite by chance this afternoon whilst looking for an answer to a plumbing question that I have following a rebuild of an annexe at our house. The annexe has a small ensuite containing a shower, washand basin and WC. The builder completed the work just prior to...
