Discuss Fixing a large mirror to bathroom cabinet door in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. darren bruce
    darren bruce New Member
    Hi
    Need a piece of advice please. I have a large made to measure mirror which I intend to fix to our bathroom cabinet door. I want to know which product is best to use to do this? I was thinking of using CT1 adhesive but would you use something else / issues with my approach?
  2. townfanjon
    townfanjon Trusted Plumber GSR
    I do a bit of work for my local glass merchants, they only use mirror bond type adhesives .
    I will reply later with a brand name , I have some at home , but your local glass will help .
    Definitely key the door you are fixing the mirror to .
  3. rpm
    rpm Trusted Plumber
    Corner brackets.
  4. rpm
    rpm Trusted Plumber
    How large is large in this case, just thinking a LARGE mirror can be heavy. ;)
    • Like Like x 1
  5. townfanjon
    Modern day mirror will only be 4mm pal it wont weigh a lot .
  6. Murdoch
    Murdoch Member
    Buy a new bigger cabinet?
    Surely a larger mirror on a smaller door might look a bit odd
  7. darren bruce
    Hi
    Murdoch? Unsure what you mean or where I say the cabinet isnt large? Its a large cabinet door and its a large made to measure mirror (as mentioned in post).
    Id say its approx 110cm high and 40cm wide and not very thick so its not HEAVY heavy :).
    A friend mentioned a silicone adhesive like GB Pro or CT1 so wondered if that was in line with yuor thinking?
  8. rpm
    rpm Trusted Plumber
  9. Watts
    Watts GSR
    I've helped joiners stick up some huge mirrors, about 3m by 2m and they just used mirror grab adhesive. Hope I never have to stick up a mirror that size again, squeaky bum time.
  10. Stigster
    Stigster Plumber
    CT1 do list their product as suitable for holding up mirrors. I rate the product highly, it's got great "grab" properties and is a reliable fix in my opinion so that's what I would use.
  11. Darren Jackson
    Darren Jackson Plumber GSR
    I always use a mirror adhesive supplied by my glass man, 1 tube is enough for even the biggest mirror and make sure your glass man has put a backing film on it.
Loading...
Similar Threads - Fixing large mirror Forum Date
Soldering fixings to the side of pipes without t's Plumbing Forum May 4, 2018
