Discuss Flexihose for Boiler top-up in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Deleted member 98531
I have a Worcester Combi and require a flexihose to top-up the water pressure. But, I need one without wing nuts as the internal piping stops me using tightening a wing nut. All seem to come with wing nuts. Where can I get one without a wing nut?
I bet it will go. It will just be tight and a slight bend of the pipes might be needed. Never seen one without wing nut type.
The wing nut is to make the loop part L compliant, so it can be easily removed. You'll probably have to look at non-UK sellers for one that doesn't have wing nuts on.
Or a tap to tap flexi
Reply to Flexihose for Boiler top-up in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi! Hoping for a bit of help! Thought I had an easy job of changing my toilet seat however it seems to be more challenging than I thought. It seems there’s no screw under the chrome. Just one long screw with a wing nut underneath. Please correct me if I’m wrong. The toilet seat also doesn’t...
1K
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer called the next day and diagnosed a faulty pressure switch. This was changed and everything seemed ok. However then the boiler began to lose pressure...
Hi everyone, Would anyone know which side valve I need to use in order to top up pressure on my boiler. Many Thanks in advance
the pressure of my boiler looks unstable After i re-pressurize to 1.5 bar, using tap is ok without problem. but when turn on the central heating, the pressure rises over 2 and the error code 117 showing water pressure high After i did the bleeding and re-pressurize to 1.3 bar, the heating is...
A
Hi, I am replacing a leaking push fit flexi tap connector under the bath with a compression fitting flexi. The problem is that the old pipe seems to be slightly smaller than 22 mm compression fitting and when I tighten the compression nut the whole fitting is easily sliding off the pipe and...
