Discuss Flowsure combi oil boiler Hot Hot Water and Hot Hot Rads ouch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all
we've a Flowsure combi oil boiler circa 2003ish. Thermostat set at low (mark at 4 o clock) Radiators are roasting to the touch and water scalding. TRV's are all working. Guessing the thermostat on the boiler could be dodgy??? or could it be something else. Definitely burning plenty of oil though lol
Reply to Flowsure combi oil boiler Hot Hot Water and Hot Hot Rads ouch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Firstly I won't be touching or going anything... I only want advice if this is right.. my partners dad has a aga that is solid fuel unregulated heat source and a oil boiler. The problem the hit water cylinder doesn't have a stat thus why the hot water is roasting hot but there is a pipe stat on...
Hi all, I have a wallstar combi oil fired boiler. We got low on oil a couple of weeks ago but didn't run out. Since we've had our oil delivered the boiler won't fire up when hot taps are turned on so no hot water. The boiler fires up periodically to heat water but not when we turn on taps. I...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new well maintained Worcester combi boiler. We weren’t convinced the heating was working right and then got hit with a £610 energy bill for the first 6...
MartinPod81
M
Hi All Bit of an urgent one being that time of year and can't get a plumber out until after xmas even on an emergency callout I have just tried to turn on my CH for the first time this year as I have a number of guests coming for xmas dinner but even after an hour all the rads are stone...
I have a Combi boiler and, a few minutes ago I turned on the hot tap in the kitchen and the water was far from hot. In fact, it was decidedly lukewarm. I checked the boiler and the tap icon was lit up, showing it was delivering hot water to the taps and I could hear the boiler running and the...
