Discuss Flue terminol....... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
wanttolearn
Hi guys plz don't SLATE me on this. I'm a newbie to the gas industry but have been asked to move a boiler for a customer.
Where they want to relocate the boiler the external wall is all wooden cladding over existing stone work.
Question is.
Is it ok to fit the horizontal flue because of the wooden cladding??
Boiler is a baxi duo tec 33ga
I would cut a section of the cladding where the flue will be hoing through. Maybe put a sheet of superlux up to fix the boiler to rather than fitting it to the cladding its self.
External cladding if so your fine just make sure there's a couple of mm clearance all the way round but would need a new flue
Be fine with any new boilers flue temp is very low, a lot are made of plastic. the older boilers flue got a lot hotter, check out the difference with your analyser when you get the chance
Give the manufacturer a quick call if your instructions don't answer the clearance question.
Reply to Flue terminol....... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We are considering buying a house which currently has a 20 year old Ideal Icos boiler, so we're factoring in replacing the boiler soon. Current boiler is on an external kitchen wall with the flue going straight out. However, it's positioned in between a door and the kitchen window, quite close...
E
I reckon if I did a survey of 100 heating engineers, asking what would they recommend for heating a granny annexe being built onto the side of my house, in place of the garage, most would give me a suggestion to put in a) an extension to the existing boiler rad circuit & electric water heaters...
eco-heating options
E
T
Morning, Im in a top floor tenement flat with access to the attic space. I have a combi boiler with flue that emits vertically up through the roof. My kitchen is situated internally with no easy access to an external wall. Could I fit a kitchen extractor that ducts vertically then right angles...
E
Hi all, Apologies if this has been covered elsewhere but I can't find an answer to my questions. I have a back boiler and gas fire which h has been serviced regularly over the years by different engineers with no issues. Last time , the guy wanted to condem it due to not being compliant with...
Hi, I have just noticed a damp patch around where my boiler flue exits through to outside wall along with a rusty colour around the collar of the flue bend. I’ve checked the external wall & there’s no water coming in from outside but the flue terminal also has a rusty colour. My regular boiler...
1K
