Discuss Flush valve replacement. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone recognise this flush valve? It's broken and tends to let water pass ...
Looks very cheap and nasty. I have replaced relatively similar-looking mechanisms because they were not working. You don't have to stick with the same make and model flush valve, you know.
Reply to Flush valve replacement. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, can anyone identify this flush valve, there are no manufacturers marks on it, the seal needs replacing, thanks.
Hi all, I am trying to find an alternative flush valve to fit the cradle of a ideal standard push btn flush. It is all tiled in and changing to a Siamp or fluidmaster is not an option anyone have any ideas Thanks
Has anyone if this flush valve using the handle instead of the button? Are they good?
Hello, I have a question on flush pressure. When I press the bigger button, there's hardly a flush. I understand that's normal but it's a very minimal flush. And then the smaller button is quite hard to press and I think doesn't do a full flush either. So when I flush I press both and it works...
My toilet flush valve is continually draining (the rubber seal has perished) . . . I'd be grateful if someone could give me a link to parts that will fit in there and replace the current valves?
