Discuss Flushing central heating system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
How often do you flush , replace inhibitor in closed system. Partly extended in 2008.
Every 5 years drain flush and refill adding new inhibitor to the system . cheers kop
Reply to Flushing central heating system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
