Discuss Free Standing Bath Drainage in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
Thread Status:
  1. luke4321
    luke4321 New Member
    Hello, complete novice here.
    Recently our bath has been incredibly slow to empty, resulting in having to plunge it recently to get any thing moving.
    After plunging over a few weeks, looking down the hole I could see a bit of scrunched up grey rubber (it had started to flow ok around this point).
    Not wanting to poke it or push it disconnected the bath and flipped it over to see what it is. Please find pictures attached. This was completely screwed up in the waste pipe.
    Ive tried placing it back in the waste pip but it just remains flat, which I can only see blocking the water again.
    Do I need to buy a replacement part/parts?
    Also I'm a little concerned about this being sealed up properly, a lot of clear rubber came apart on the thread when I undid it.
    Any help would be hugely appreciated, Thanks.
  2. ShaunCorbs
    It looks like it's part of a waterless trap
    And your best bet would be replace the whole trap for the same type
  3. rpm
    rpm Trusted Plumber
    The clear rubber on the thread is a silicone sealant the installer used for some reason.
  4. luke4321
    luke4321 New Member
    Thanks for the quick responses. I'm going to pop to B&Q to see if I can find a replacement. Is the silicone sealant necessary?
    Thanks.
  5. ShaunCorbs
    No
    • Agree Agree x 1
  6. Chalked
    Chalked Plumber GSR
    It will be a hep V0 water
    Ess trap
  7. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    I would also say it looks like the centre from a HEPVO
  8. hammers4spanner
    hammers4spanner Plumber GSR
    If its is slow to drain then was the hepvo trap fitted the correct way ? The space under a freestanding bath to fit a trap is very tight hence why they have used an elbow onto this style of trap . As they have siliconed the elbow tells me they are possibly no idea about plumbing as you can still clearly see that the black o ring is still in the elbow.
    Just stick a new hepvo trap in with the arrows pointing the way the water drains, also make sure you have enough space under the bath for the trap.
  9. luke4321
    luke4321 New Member
    Thanks for the responses, and for identifying the type of trap as my local B&Q didn't have anything like it. I assume the rubber piece allows water out but blocks out any smells coming back up? (as have put everything back for now and the smell is bad) Will look to getting the replacement trap sorted from plumbing store.
Loading...
Similar Threads - Free Standing Bath Forum Date
Sign up to the CORGI direct newsletter and receive FREE shipping on your next order Plumbing Forum Wednesday at 4:57 PM
Freeze master or Rothenburg rofrost Plumbing Forum Jun 18, 2018
Thread Status:
