  • Thread starter Carol Baxter
  • Start date
  • Replies 1
  • Views 840
  • GAS fire
Discuss Fuel Effect Ltd Hotbox fire in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Carol Baxter
Hi, I have a Hot Box Fire by Fuel Effect Ltd who I understand have gone into liquidation. I need to locate a manual as I need to know how to put the pebbles in correctly. I cannot find one on line. Can anyone help me.
thanks.
Reply to Fuel Effect Ltd Hotbox fire in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Guys, My chimney failed the test so I need to install a flue liner for my Gazco Stockton gas fire. It was over a year ago when the engineer condemned the chimney and I remember him also saying something about it needing some sort of box fitted into the fire recess but I can't remember the...
Firstly I won't be touching or going anything... I only want advice if this is right.. my partners dad has a aga that is solid fuel unregulated heat source and a oil boiler. The problem the hit water cylinder doesn't have a stat thus why the hot water is roasting hot but there is a pipe stat on...
J
Hi all, I am a plumber but I do not carry out works to boilers as the majority of my is bathrooms so I am not gas safe. I have completed a bathroom for a regular customer. She is of old age and is starting to get a little clumsy and her son has asked me to look at the old gas fire/back...
Hi all, I have a wallstar combi oil fired boiler. We got low on oil a couple of weeks ago but didn't run out. Since we've had our oil delivered the boiler won't fire up when hot taps are turned on so no hot water. The boiler fires up periodically to heat water but not when we turn on taps. I...
Hi, I wonder if anyone here can help me in resolving this issue. The meter I have stops at 19mbar with 'out of range' message and I cannot use it for other pressure checks. The instruction manual is not helpful. I contacted Digitron but they are not replying. The meter range is upto 130mb...
