Discuss G3 literature recommendations ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
macka09
hi all. Are there any books about that would be worth buying to gain knowledge of unvented installs and regs?
The bpec vented and unvented one is good
As well as the guys above have said , I would advise you to actually read a copy of G3 , no idea where you would get one .
I read it once , and will defo try read it again before my next assessment
Download a set of manufacturers installation instructions. All in there.
No need for a bad install these days all the instructions come with them. I suppose some muppets just can't read.
Reply to G3 literature recommendations ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Looking for a recommendation for a heat only boiler to replace my 30yrs old ideal boiler. Any makes you would recommend and any to avoid? Thanks
Hi, According to the regs, can I (homeowner/DIY-er) drain and refill an unvented cylinder myself, or does that require a plumber with G3 cert? Cheers
Hi guys question about saniflos đź’© I'm working at a property that the entire place was fed off a sani, that's packed up, blocked the line entirely and they've urgently had to get me to replace and make some changes, initially I was going to install a sanivite for the kitchen sink separately...
M
My house runs an unvented system and I plan to renovate my shower and replacing the existing one with a Grohe Grotherm 1000 Cosmopolitan Bar shower model 34437000. At the moment the flow rate of my shower at hydrostatic pressure only is 7 litres per minute. The shower head is about 1.5m below...
Min Chew
M
Hi all, looking for some recommendations for a slimline indirect unvented cylinder to go with a new system boiler that we're having installed soon. Only need around 120/125 ltr for our usage and could possibly make do with 100. Been looking at a few different brands including the Megaflo which...
