Discuss Gas pipes and cables in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
Went to a job today where they have had new gas and electric supplies installed
The armoured cable us zip tied to the galv gas supply.
Cut it off?
Reply to Gas pipes and cables in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have an old gas pipe in the understairs cupboard. The previous occupants had the gas meter moved, but this old pipe remained. This pipe goes behind the electrical CU which I'm due to have replaced soon. We are looking to cut the old pipe out, but trying to working out what material it's...
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a gas warning notice for at risk as the outside wall meter box has been drilled through for the gas pipe to go horizontal straight to the boiler. The...
Hi, Non-professional / knowledgeable person here. I'm a Brit in Romania who volunteers for a charity building an old peoples home for needy old people. Out here competence and integrity is harder to come by in a worker, in fact it's hard to find workers at all where we are in the countryside...
C
Hi All, I have the boiler above and the safety thermostat has snapped at the plastic cable right where it means the thermostat. This looks like it was originally all one part but can’t find the replacement harness and thermostat only the thermostat on its own with two electrical connections...
Deleted member 120897
Full disclosure, I am an Electrician. One of my older clients has just had her fire capped off because it doesn't comply with today's regs and was told the regs are now retrospectively applied. This is the opposite of what I am used to. For example, if I do an electrical inspection and find a...
