Discuss Gas pipework running through another property in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mfgs
I have been asked to take on a job which isn't complete due to the building company going bust. So there are a few flats that need to be second fixed etc. The main gas runs for each flat are chased into the wall and run up from the ground floor to the third floor. These have been hidden behind a large architrave around a big sash window, there are joints in the pipes and obviously only the wood separates them from each flat as the pipes go up. If that makes sense?
Is there any way in which you are allowed to run the gas pipe for one flat through another?
I have always done external runs or through communal areas and fire proofed and ventilated duct to outside if needed. Obviously now the flats have been constructed etc this is more difficult so just trying to explore any available options as I am struggling to come up with anything other than external re-runs.
I think you've answered your own question. Unless there is an internal service void through the building then the gas service pipes will need to be run externally with AECV's at point of entry to each property with a label at each meter pointing where this is.
Yeah, I was just kind of hoping there was a way around it to be honest. I just couldn't see one. Think I am going to swerve this job, too busy as it is. I don't need the headache of putting right someone elses balls up.
I think it would have to be on the deeds of the property it passes through, access could be needed at any time
Sounds like a can of worms
Yep, give that one a wide birth,
Big legs
Runaway
Reply to Gas pipework running through another property in the Plumbing Jobs | The Job-board area at PlumbersForums.net
