Discuss Gonna be a busy day Monday in the Plumbing Jobs | The Job-board area at PlumbersForums.net
markfxy
Got this little lot to install monday 300 sq metres downstairs, upstairs is going to be a nightmare builder won't batten the joists wants them all notched :mad2: quite a few are at 200 centres I've told him to do one.Builders you gotta love them:yes:
you going to put a lever valve before the port valves, so to help with servicing afterwards?
yes I'm going to take out those crappy compression fittings on the bottom of the two ports an replace with compression copper to irons then a lever valve, I dont know why they use them the olive sits flush with the end of the pipe and the dam things are a nightmare to seal!
Reply to Gonna be a busy day Monday in the Plumbing Jobs | The Job-board area at PlumbersForums.net
