Discuss Good practice for exterior kitchen-waste pipework in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Chuck
Subscribed
Hello UK Plumbers
I've sketched the current arrangement for handling my kitchen waste water on the attached diagram. The pipes have become brittle with age (>25 years AFAIK), I don't like the discharge end which tends to get blocked with leaves and wets the concrete before it gets to the gully. Also, it's just used 90° bends at the point the pipes come through the wall so a blockage would be a problem to deal with.
I've had a look at section H of the BR and have come up with a new 'improved' layout, which I hope complies and addresses the problems with the current arrangement. (The condensate is from a new WB 24i with a decent sized siphon so the risk of freezing is fairly low.)
Sketches, to scale, are attached. My specific questions are:
Does my design look okay and comply with good practice?
Is my reading of section H, which is that the discharge should be below the grid but above the water level the gully, correct?
Which brand of 40mm solvent-weld upvc pipe and fittings are best quality for this job? I'd rather spend a bit extra and get something that is likely to last well. I'm in Devon and the wall faces west so it gets quite a lot of sun (and rain!).
Thanks in advance for your advice/comments.
Chuck.
looking ok to me i wouldn't put an access cap where it comes through the wall, just have it on the up stand for the sink
just below the grid or 1/2 below the grid top
and tbh there all about the same from a plumbing merchants
polypipe or terrain are good
To be honest, there wasn't much wrong with the original layout if the ends of the pipes had been both put down into the gulley. Often 135degree bends needed to angle down.
I agree with Shaun that I wouldn't use an access cap as no need. Keep it tidy. Also use waste pipe that suits colour of other downpipes etc. If you do not paint the outside wastes then UV rays eventually damage them, although can last well.
Do be aware that someday when that gulley blocks, which it will unless you fairly regularity clean them, then the wastes ends will be into the water in the full gulley and washing machines will pump waste water out of any standpipe inside! Some of the ideas are not so clever in regs. IMO the wastes above the gulley a little and a leaf guard locked in place around it all is the best job.
Reply to Good practice for exterior kitchen-waste pipework in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Size of bathroom 230cm x 210cm Height 230cm Birmingham Area Initial problem Burst pipe underground in bathroom, concrete. Have had this dug up & made safe for now, have had affected pipe cut & put end caps on. Work required Full bathroom remove old tiles walls and floor. Renew tiling. New...
    • Useful
My parents have a leak from kitchen sink. My dad removed waste trap and since refitted it leaks, but there wasn’t any kind of seal on it, I got a rubber/plastic gasket that seems To fit the trap but with it, I can’t get it to screw and lock back on (has lugs so locks after quarter turn. But...
I am trying to workout in what order my radiators heat up in order to then balance them. I am able to figure out which radiator pipe is the flow/return on each radiator so that I can then grab the right pipe to check which heats up first. There has been an extension done on this house at some...
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of copper pipe between compression fittings on the hot water feed. There are take offs for an outside hot and cold tap together with isolation valves and...
Hello. I am planning to build a small half bath in my garage, next to a washing machine, using old showers plumbing. There was a stand-alone shower in the garage which has been removed. Unfortunately the pipes are only 1.5" on that side of the house since there's no bathroom and the house is...
