Discuss Grant vortex eco oil boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
andyplumber
Hi guys
I fitted a wet room a couple of weeks ago including a new towel rail
The customer is now claiming her boiler is not working properly and it was fine till I did the wetroom, all I did was drain the heating down, fit towel rail and fill it back up, fired it up and it all heated up hot water and heating, as it a oil boiler I won't touch it I have explained I'm not oil qualified, the boiler fires up normllly and heats up until the boiler stat reaches temp, it switches off for 2 minutes, then fires up for 4 minutes and it does this until it turns off on the clock or manually
Customer is saying it never used to turn off and back on again?
I have suggested they employ a oil engineer but it falls on deaf ears
Air lock on a couple of rads causing it to cycle?
i have replaced the pump thinking it was weak pump, when i changed the pump it did shift a bit of air, i installed a auto air vent but the boiler still fires up then turns off, and a radiator was full a sludge which i have flushed out, i have check the vent pipe to make sure its not sucking air in and replaced the 3 port valve.
Flow and return temperatures?
What are they?
i checked the flow and return temp last night i was getting 19-20 degree difference 72 flow 51 return thats with boiler the stat at maximum.
Does it have a By-pass ?
Is it open?
Have I got this right ?
Boiler fires, comes up to temp, all Heating and DHW get hot, Boiler knocks off, then cycles ?
If that's the issue, it must have been like that before!
I would also think the boiler must have been always like that. If everything comes up to full heat after an hour or two, but boiler continues to cycle, then could be the nature of the boiler stat. I have seen same thing with Vortex boiler.
Is the boiler internal?
Sounding like the old "You touched it last!" trick Andy.
I`ve had it tried on me, I fixed the sani and got blamed for the flush not working as it used too.
Yes you have pretty much got it right all rads get hot and DHW, no bypass.
I also think the issue was there before i started but when you get that old saying "it was fine before you got here" I can't help but try and sort it plus I wanna get paid lol, I think in future i'll fire boilers up before drain down. the only issue i saw with the heating was it was full of sludge when I drained down the first time to do the first fix, and i treated it with fernox f3 and flushed it out on second fix
The heating heating pipework is the old non barrier hep20 which doesn't help with sludge.
I am waiting for the next "it was fine before you arrived", probably for a broken tv not washing machine LOL
Reply to Grant vortex eco oil boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Grant Vortex 50/90 condensing oil boiler where the air tube spigot over the fan is not connected to the existing flue, should this be closed off with a Reillo cover plate to stop vermin getting into the open fan motor.If is blanked over will need a further combustion test to confirm adequate...
We have an oil delivery booked for Friday but we ran out earlier today. We topped the tank with 150L from containers, bled the first boiler from the Allen key until the oil ran free and it fired up fine. Did the same on the second one but that had an E9 over temp error. We reset the thermostat...
Any advice welcome as plumber stumped Had 36-46 grant vortex utility boiler 7 years no problem recently oil tank move and tigerloop install (tank about 1m lower). 10 days later and boiler either doesn't fire or fires stops, fires runs splutters stops. Most it runs now is 10 mins, but that's...
Hi Oil experts. I had a grant wall boiler with a failed transformer. Carried out a service and pretty sooty nozzle, and baffles build up suggest not cleaned in a while. The bottom baffle on the left corner had completely burnet through. Any Idea on the process on how this occurs and why just...
Hi all, I have a wallstar combi oil fired boiler. We got low on oil a couple of weeks ago but didn't run out. Since we've had our oil delivered the boiler won't fire up when hot taps are turned on so no hot water. The boiler fires up periodically to heat water but not when we turn on taps. I...
