Discuss Grey Water pipe size? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
I have a grey water waste pipe which keeps getting blocked. The pipe is 50mm, and connected to it is a W/M, D/W, 3 x sinks and shower/bath.
Should the waste pipe be larger than 50mm, and is this the reason why it keeps getting blocked?
Any advice much appreciated.
If it is getting blocked, then it is to do with something being put down it - like food or grease down a kitchen sink, for example,
- or, more likely your waste pipe in wrongly installed and doesn't have a correct fall, not clipped and sagging somewhere, etc, allowing waste to fill with water causing an airlock and/or blocking with hair, soap or other.
With all those fixtures connected - no wonder it's blocking.
Saying that, very unlikely that all fixtures are being used at one time.
Could be down to a gradient issue, no: of bends & junctions, length of drain and venting issues.
The drain design doesn't sound desirable but there are many factors that could make the drain not work at all
Agree with comments above. Not a great idea to use 2" pipe for all of that and may be slow if you're trying to use all those appliances at once, but shouldn't actually block. Could be as simple as someone hasn't bothered to deburr the internals of the pipes at joints and hair etc is getting caught on them. Or, as Best says, not properly clipped or sloped etc.
If it's blocking, are you able to find the exact place it blocks up?
Ok, thanks. The pipe is going to be re-run to provide a greater fall and reduce the number of bends. Hopefully this will reduce the likelihood of it block again.
All advice appreciated.
Reply to Grey Water pipe size? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I will need: install new 100mm pvc pipe work, 90-degree bend for new W/C install new 100mm pvc pipe work, 90-degree bend with new gully pot at rear of new extension for sink waste clean water pipe carry out 2 x Lead connections with a new T section No excavation needed, all is digged out.
Hi, grateful for any advice I need to connect a dishwasher waste water outflow pipe 25mm to 50mm waste pipe. Is there a joining piece anyone can recommend? Maybe with some appropriate tape. The waste pipe is in the wall but was trimmed at some point (unnecessarily) to only 10mm extruding from...
Hi! Totally inexperienced DIY newbie so bear with me for descriptions! Pictures hopefully help. I’m trying to remove an unused downstairs toilet in our new house. It’s eventually going to be moved to the other side of the house. The seal around the back of the toilet had failed so I switched...
Hi everyone I hope you can help. We were getting some work done and our builder attached the boiler condensate pipe to the sink waste pipe. This was all then covered with dot and dab. Shown in the picture, red arrow. So the only thing visible now is a round pipe from the wall. We are yet to fit...
Hi, came across this old push fit waste pipe. Stripped out the old shower and it was a 40mm waste pipe siliconed in the fitting. The fittings at floor level so I’d be looking to bend (90 degrees) straight away so I can get the lowest possible shower tray. Could someone advise what I could...
