Discuss Grohe isolating Valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Basically connecting an isolating valve ( Bsp thread male ) into an outside tape fitting ( Bsp female ) wrapped Ptf tape around 12 times ... still got a bloody tiny leak
Looking for a belt and braces solution as I'm going to use a few of these as I go when revamping house
I've used Fernox lsx in the past should I revert to this or similar or a bit of both ? Can provide pics of both if necessary
Ps the thread on Grohe fitting is serated
Cheers
Just been googling should I have put a rubber washer in the female fitting for the male fitting to bed into ?
Try it with Loctite 55 rather than PTFE. Wrap it in the direction of doing up, laying it across the threads in a sort of zig-zag pattern. The benefit of using it is that you can back the fitting off a bit (though I wouldn't go more than 1/3 turn) to get the orientation right.
Or loctite 577
Had a quick gander on net ( not heard of it or used ) looks like a cottony thread ( like hemp ? ) 64 000 dollar question how much do you put on and do you let it cure ? And once cured does it come undone or set solid ?
1. With nothing on either part, fit together. If they screw together in a slack way up until the base of the valve hits the base of the female threaded fitting, it suggests the male thread is parallel rather than tapered. If the thread gradually tightens as they go together, the male may well be tapered.
2. If parallel I'd start with 10 turns, if tapered, around 5.
3. Wrap around zig-zag fashion as stated above, then try. If no leak, back off to required position (or tighten if possible and fewer degrees of turn required) then try again.
4. If joint leaks, disassemble, remove Loctite (fiddly), remake with 5 more turns and repeat as above.
5. It doesn't cure, so no need to wait. Joint can be disassembled in the normal way.
I've never used Loctite 577 as ShaunCorbs suggests, but it does seem to get good write ups.
It's parallel defo 6 1/2 turns it stops dead and I bought a 500 mm flexible ss tap connector so got plenty of tolerance as to where it stops and it's tucked away under the cistern looks lovely and neat ordered some Loctite from Amazon for tomorrow had really good reviews thanks very much for your help
Hi I used it and it worked a treat just wondering would you use it on a standard compression fitting ( 15 mm ) I normally just smear some Fernox LD-X works ok but just curious of what you can use it on
Reply to Grohe isolating Valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
In short: Do suppliers sometimes list BSPT as BSP? I need a tee, 22mm each end with a BSPT in the middle for an expansion vessel to dangle from. Why I think its I've used calipers on the threads and counted them, and the male end sticking out of the vessel is BSPT 3/4 with 14 threads per inch...
Hi Just had a new bathroom installed with a toilet bowl that reaches the back wall. Its has a bottom entry cold feed to the cistern. The fitter put an isolation valve on the pipe work for this :-(, the copper pipe comes up from a plastic pipe push fit. See photo. I did a tissue paper test and...
1K
Morning all. I hope this is the correct place for this post. If not i'll happily move it to another forum area. I am renovating a property and the old cast iron radiators need a refresh, and i'm going to fit some new bleed valves amongst other things. The female thread in most of the rads...
Purchased a Grohe Basin Tap with has 3/8" flexi tails., but i notice the flexi's have no internal washer. I have purchased 2 Compression 15mm x 3/8" tap connectors from screwfix.... Part No.: 6089R and will fit these into two 15mm isolating valves. The question i have is that will i need to...
1K
… praying to the plumbing God, Bob Pictures and layout details attached, so be patient. 21 year old oil fired system in pretty good nick. I noticed some minor pumping over from the vent (occasional burst of water, and the odd dribble). Didn’t think much of it as I was about to replace the...
