Discuss Grohe Thermostatic Shower Mixer Bar - Flow Valve Removal in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. David Freer
    David Freer New Member
    Hi Everyone,
    I have a dripping show, so I need to disassemble my thermostatic shower mixer bar. The water flow valve is made by the company Grohe. The valve has a small slot (see red arrow on first photo). If I insert a screw driver the valve lifts slightly from the mixer unit, but this seems not to be the only fixing mechanism as the valve still does not come away from the mixer bar.
    I would be really appreciative of any help on this!
    Many thanks,
    David.
  2. rpm
    rpm Trusted Plumber Top Contributor!!
    Could be stuck from limescale David, suggest you try a little harder or try the showerdoctor.com (be prepared for a two day delay in response though).
  3. David Freer
    Aw, thanks very much rpm. The cartridge is pretty stuck so I really think there must be some other fixing mechanism. I'lll wait a day or two to see if anyone else can help me. Otherwise - I'll try your recommendation - I guess you mean showerdoc.com ??
  4. Allgoode
    Allgoode GSR
    Hi David,
    As you have a bar shower valve with (150mm pipe ctrs) it might be more cost effective to replace with a brand spanking one rather than changing cartridge as Mira & similar have a 5yr warranty.
    Just a thought,
    Good luck ,
    Andy (Allgoode)
  5. David Freer
    Thank you for your advice Andy. Much appreciated!
  6. YorkshireDave
    YorkshireDave Plumber
    Id email Grohe Germany (don't bother with the UK bunch). They are really helpful.
  7. David Freer
    Thank you very much YorkshireDave,
    that's very interesting. I did indeed try through Grohe UK and they were not able to help me, so will try the Grohe Germany if I am still stuck.
    • Like Like x 1
Loading...
Similar Threads - Grohe Thermostatic Shower Forum Date
Grohe thermostatic mixer making noise Bathrooms, Showers and Wetrooms Aug 7, 2018
Hansgrohe/Peglar low pressure? bath shower diverter top parts? Valves & Taps Aug 3, 2018
