Discuss Guage vibration in the Central Heating Forum area at PlumbersForums.net
Has anybody come across this before? My pressure guage is vibrating and causing a horrendous noise in the pipes. Not sure if just changing the guage will fix the issue
  • received_891987841420549.mp4
    444.2 KB
Nope never see that before and the filling loop is shut
It looks like water flow is altering rapidly.
It could be a number of things.
I suppose it could be a gauge issue but to me it looks more like water flow is altering rapidly. Have you checked non-return valves or pressure relief valves on the system?
I don't know why this is in bold writing by the way, I don't remember altering anything and it isn't me being dramatic.
I think I found the issue. The lockshield valve on the towel rad was nearly closed. Opened it up a bit more and the vibrations stopped.
Reply to Guage vibration in the Central Heating Forum area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
