Discuss Halstead spark lead replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Halstead hero 60 boiler works fine but spark lead is a bit tatty and all spares sites show it as obsolete, if it burns out what grade of cable couls I use to replace it , or could I use a cable of suitable length from a different boiler?
Are you gas safe uncle Barry ?
No, but my plumber is, just to add, I suffered from late ignition with this boiler for years, had every gas safe engineer and his uncle look at it and no fix. I found the problem when a new board was being fitted (by a gas safe engineer) the spark lead comes out of the board at a very tight angle and is hard up against the boiler casing causing a short which reduced the amount of oomph to the electrode, two pieces of insulation tape cured it, really bad design fault and before you tell me I know Halstead made rubbish boilers.
Reply to Halstead spark lead replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
