Discuss Heat loss calc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
eaton
Just trying to do a heat loss on a house requiring air source. Used the Quinn rad app and set for 55degree flow, 4 bed bungalow and heat loss came out at 17 kw!!!!! I'm sure it's wrong, anyone use anything better or have a programme they would recommend
Hi, Ive just been on the Husky air source heat pump course they had a heat loss calc program on there website. Seemed to be very
good and straighforward.
Id advise giving them a call as they were very helpfull and will also comission your first install and advise on the installation.
Ps you will need a installer code to get on to the heat loss calcs. Hope this helps.
i fit daikin, my flow rate setting is never more than 48 degrees, that might help your calc!
Reply to Heat loss calc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
