Discuss Heat only recommendations in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
I haven't fitted one for ages
What's good st the moment?
Something with a decent warranty, compact and ideally not needing pump over run
Viessmann baxi anything with a ss hex doesn't need po
Is the baxi 400 and eco blue advance the same boiler with more warranty?
I have only ever come across 1 viessmann combi
I guess I wouldn't be able to offer much warranty as a newbie to them
Near enough
400 has 5 years
Eco 2 years
Do vaillant need pump over run?
Are they still SS or ali heat exchangers?
SS unless you fit the ecofit range and it is best to have over run but if it is not physically possible Vaillant do a link/suppressor kit that you fit to the boiler.
Reply to Heat only recommendations in the Plumbing Jobs | The Job-board area at PlumbersForums.net
